Had to remove the spare for my after-market trailer hitch install. I couldn't get the spare tire retaining winch yellow dot to appear. It was rubbing against the new hitch so today I lowered the hitch and shifted it to the limit of its slotted bolt holes. Better, though still some rubbing.
However, the spare now went back even worse than before. So I increased clearance and the spare tire stows worse? I pursued and discovered that apparently the spare tire holder has to have a certain orientation or it hangs up leaving the spare tire hanging below being secured.
I lowered the spare and using a flash light, observed the require orientation through the wheel rim. I rotated the spare and held it in place while cranking the winch. Voila! The yellow indicator filled the window as well as the spare was now secure.
One more point, I read "Yellow DOT" as being a yellow D-O-T, as in Dept. of Transportation. So I was looking for the letters D, O, T, in yellow to appear. But what you get is a solid yellow oval filling the oval window. Is this an Italian thing, saying DOT when you mean dot (which it still isn't).
