i had to remove the tire to install the hitch. under the passenger side is a black plastic box with all the tools you need to lower the tire and change tire with if needed. when i reinstalled the tire -- at first i didnt put it in right - the metal bracket hit the frame and couldnt tighten the tire up, but i can tell you if you crank it too hard - it just slips in the cogs. grrrrrr. i was able to turn the metal braket and it when up right , but i can tell you its not the most secure feeling to crank on that cable winch to tighten the tire - its like its got a magic spot of tightness.
