1 - 20 of 44 Posts
I am seeking to remove the spare tire from under the van and place it on the rear door, does anyone know of a good tire mount?
I have a write up on this in my build thread. Search Jostalli's Build.
I used a spare tire mount from a Jeep Wrangler. Perfect fit. No issues.
Thank you Jostalli for your reply, your setup is sweet. Do you see any disadvantage to mounting it on the other door?
Thanks.
Yes. You would be covering the door handle.
Hi, Jostalli
The tire with the rims weighs 70 pounds, even with the Reinforcing Kit i am concern the weight will damage the door, have you experienced any issues?
Thank You
Hi, Jostalli
Thank You
So far so good. I haven't gone off-roading yet. The only thing I noticed is more squeaking/rattling at the door jamb.
Discussion Starter #7
Is that only when you open it or also when you drive?
I will be installing it this weekend. i have purchased the "Rampage 86610 Rear Tire Mount Kit Extender" and will try that one.
http://www.amazon.com/gp/product/B001OMRDQW?psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s00
When I open the door? No I'm talking about squeaks and rattles while driving. This van has a lot of squeaks and rattles in the doors and the extra weight just makes it worse.
Now that I'm thinking about it I am going to go grease them.
Time to time is useful to lubrificate the rear door hinges to prevent metal fatigue in the door around the hinges (when X250 model arrived in the market in 2006-2007 that problem for some users, for example delivery companies).
Usually when You get the van for service it should be checked and lubrificated if necessary... but You never know... some dealers doesn't even check tyres pressure on new vehicles prior delivery to customers.
dolmundo, thank you for the picture of your spare on the rear right door. How easy is it to reach the door handle? I'm thinking a child/shorter person would have to step up to open the rear door.
Discussion Starter #14
I inverted the handle so it opens down not up, I think if you are not tall enough then you will need to get on the bumper to open it.
In my build I sacrificed the spare tire for propane and water tanks, relying on a tire sealant kit for flats. I was a little worried that the sealant kit would not always work so I mounted the spare tire on the left back door using a Smittybilt carrier for the 07-14 Jeep Wrangler. This unit has a center post support for the wheel that makes it much easier to place the heavy wheel on the carrier. I fabricated a welded angle iron bracket that bolted to the mounting holes for license plate holder, which required that the license plate be relocated to the right door. Angle iron reinforcement bars were used inside the door to strengthen the mount. There was a little too much flex in the door panel from the tire weight so I added two braces connected at the bottom of the door, which significantly stiffened up the mount. Here are some photos showing the details:
2018 ProMaster 3500 159" extended Fulltime 4 season van build
Did you apply anything between the paint and the brackets? Great job on the build. Any way to lock the tire down? I know they're not super expensive but people will steal about anything. Please post up a link for the Wrangler assembly as others will want to price this idea.
...cut... I mounted the spare tire on the left back door using a Smittybilt carrier for the 07-14 Jeep Wrangler...cut...
Did you have to do any mods to the park sense sensors?
I put some extra thick Gorilla Tape on the angle iron parts that contact a painted surface. As far as locking the spare I think I will probably use a cable bike lock. Here is a link to the mount:
http://www.smittybiltdepot.com/Smittybilt-Bumpers-Tire-Carriers-and-Winch-Mounts/Smittybilt-Oversized-Tire-Carrier-2743.aspx?t_c=64&t_s=26&t_pt=3902&t_pn=S%2FB2743
BTW, the giant wing nut on the back of the mount sticks out too far so I replaced it with a 16mm bolt.
Super adaptation, thanks for sharing.
Does the tire interfere with the backup camera?
1 - 20 of 44 Posts
