@el Jefe
Your arrays are doing pretty well IMHO.
It looks like your arrays are fairly high voltage so the wire losses will be low and they will turn on early in the morning. Moving a kW off of the roof at a lower array voltage from panels in parallel is challenging so that can be a real factor.
Exactly why I run panels in series. Any gains, in my situation, are negligible running in parallel and the logistics with wiring, roof penetrations, upsized wiring and....are just not worth the effort.
Once you have an array Vmp that is routinely / consistently running 15 volts higher than the max battery charge voltage, then MPPT is the way to go.
I agree.
If the array Vmp label is only 5 - 6 volts higher than the max battery charge voltage, especially in an area that gets a lot of overcast, then PWM is the way to go - especially in the winter time.
In between these conditions can be a mixed bag. MPPT might be optimal for the summer, but PWM might be better for winter.
If you like playing with it, you could see if it makes sense to split the series array - if some of it remains in the sun longer?
Another path - if you were running short - would be to put some panels vertical or out somewhere where they would get sunlight later in the daytime and run a wire back to the van (with a dedicated controller)
Are you seeing times when you think that it would be a significant gain for you to have a different configuration?
Where PWM is the most helpful is
- in an area such as San Francisco with the morning overcast that does not burn off until afternoon
- Dec / Jan / Feb in this area as it is quite overcast then so solar is always running a deficit
- Fire season with the smoke
- a place like OR / WA especially along the coast
