1 - 1 of 1 Posts
I had the same problem many have mentioned--the bottom trailing edge of the slider wouldn't close easy. The solution mentioned here was to give that trailing edge a little boost when shutting. Even on level ground, I could not shut the door completely from inside.
While at the dealer's body shop yesterday, I mentioned the problem, and that I was concerned I might catch a finger (that got his attention). ;) The guy studied it a moment, went and got a driver, and tightened the little round "stop" sticking out from the body in that corner.
The problem appears to be solved, or at least much improved. At least I can close it from the inside now.
1 - 1 of 1 Posts
