Sliding door inside door handle mod to make it easy to close sliding door.
///http://www.promasterforum.com/forum/garage.php?do=viewvehicle&vehicle_id=1513///
I10. Sliding door closer helper. Closing the sliding door from the inside is not easy. You have to use alot of muscle and may have to do it several times. Closing from the outside is easy if you use you forearm to push in with the same hand that is holding the handle.
To make it easier to close, I installed a metal handle (6 1/2"), from Ace Hardware with black sheet metal screws mounted horizontally in the middle of the sliding door. Now when you close the door, a gentle pull on the handle will be enough to close the door with normal force. Total cost $10. Time: 1 hour.
