1 - 3 of 3 Posts
Hey all. I ordered a dometic midi skylight and it still hasn’t come in but we wanna get on with the van build. Is it possible to put up the ceiling and just add the skylight later? Without the ceiling we can’t build cabinets etc. and do other things we need to do. Thanks!
I wouldn‘t try to put the skylight in later. There is no reason to have to finish your ceiling first. In fact, it’s the very last thing I just did on my new build. Just plan ahead and leave enough space to slip the insulation and whatever you plan on using for the finished ceiling.
For example:
63429
Are you installing the fan in the area of the roof that is stamped out for a skylight, just behind the cab?
If so, it's flat and slightly raised.
You could always cut the hole, trim it out, tape plastic over the outside and finish the ceiling.
If you have to have the ceiling done before is arrives.
Some of the major factors on why I went with a maxxfan were delivery time, cost and cost of replacement parts.
How long did they say it would take to arrive?
Is there other stuff you can work on until it shows up?
1 - 3 of 3 Posts
