I'm trying to determine what size wire and fuse/breaker to use between my house battery and the Blue Sea 12v fuse block. My 12v load circuits are as follows:
1. TV - 2.3 amps
2. Two Rigid scene lights - 1.5 amps total
3. Fantastic Fan - 1.8 amps
4. MaxxAir Fan - 4.2 amps
5. LED 3w Lights, 9 total on three circuits (main, over bed, over counter) - 2.25 amps total
6. Fridge - 5.0 amps
7. Water Pump - 7.0 amps max
8. Two USB iPhone chargers - 2.0 amps?
9. One cigarette type charger (possible occasional use) - ??? amps
10. Composting toilet fan - ??? amps
Everything listed comes to about 19 amps. It could be slightly more if adding the last two items. The distance the wire will run from my battery to the fuse block will be about 6'. I typed it into the BlueSea calculator and it says I need to use #12 wire (12v, 20amps, 2% drop, 90degree, 6' run). Does that sound right? That seems kind of small. I wired my whole van using #12 , maybe I went way overboard.
1. TV - 2.3 amps
