I'm installing my sink into my countertop soon. The last component I'm working to figure out is the sink drain. My sink assembly has a 1" ID barbed connection
Additionally, I have a grey water tank mounted below and am plumbing all grey water into the tank through the floor.
A couple quick questions:
1. What kind of hose should I use for the drain? I was thinking braided vinyl 1" ID. Any reason to use something rigid instead of flexible vinyl? I'd like to use this drain valve, and thus I have to use some sort of flexible tubing. I could adapt to something rigid if there's a compelling reason.
2. Do I need a trap? I don't quite understand RV plumbing of sinks and showers-are traps entirely necessary to avoid smells? I know of the hepvo valves-not sure exactly how I would install with vinyl tubing-probably some adapters. What other options do I have besides a typical trap? I've seen many with the jug under the sink design-do people just not worry about greywater smell?
3. Plumbing the grey line through the floor. With flexible and with rigid piping, anything in particular to know? I was thinking of adhering some sort of PVC conduit to house my flexible drain hose.
Thanks.
Thanks.
