Did you ever get the answer to you question. My light came on today and i cannot for the life of me figure out how to get it off. Not oil change the problem you hadYes I did...The msg for oil change that you reset is "Change Oil" Msg that comes on everytime you start the van..and I did successfully resetted that one...
but this came 2 weeks later.
It’s not the oil change light. It’s service expired and there is now a wrench on display! That is what the guy above me was trying to say as well ! That’s why I was wondering if he ever got the answer to his question! Thanks for trying!From the manual
Resetting oil change light
- "Your vehicle is equipped with an engine oil change
indicator system. The “Change Engine Oil” message will
display in the EVIC display. The engine oil change
indicator system is duty cycle based, which means the
engine oil change interval may fluctuate, dependent
upon your personal driving style.
Unless reset, this message will continue to display each
time you turn the ignition switch to the ON/RUN
position. To turn off the message temporarily, press and
release the MODE button. To reset the oil change indicator
system (after performing the scheduled maintenance),
refer to the following procedure.
1. Turn the ignition switch to the ON position (do not
start the engine).
2. Fully depress the accelerator pedal slowly, three times
within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
NOTE: If the indicator message illuminates when you
start the vehicle, the oil change indicator system did not
reset. If necessary, repeat this procedure."
Really?From the manual
start the engine).
within 10 seconds.
any luck? Mine is on..Did you ever get the answer to you question. My light came on today and i cannot for the life of me figure out how to get it off. Not oil change the problem you had
No I cannot find anything on it ! Mine was right before 80k on the odometer. I believe it is a 80k service light for major service at the dealer. There must be a way to shut it off but I have not found it as of yetReally?
