41 - 42 of 42 Posts
I lapjointed and glued my ply so that it is a monolith. Six factory tie-downs have held it in place for 5 years. No screws.
i agree that OSB has no place in a van.
I'm looking to install my floor this way as well using the 6 tie-downs. What is the best way to remove these screws? Also, I'm using 1/2 in insulation and 1/2 ACX grade plywood. I assume you then simply just get an 1'' longer screws and simply create drill holes to screw back in?
I'm looking to install my floor this way as well using the 6 tie-downs. What is the best way to remove these screws? Just unscrew them. They go into fixed nuts. Also, I'm using 1/2 in insulation and 1/2 ACX grade plywood. I assume you then simply just get an 1'' longer screws and simply create drill holes to screw back in? Yes. Mark the holes on your template.
41 - 42 of 42 Posts
