One of the reasons I bought my pmcslt was that the rear seat is removable.I haven't had to yet so I haven't looked.I'm thinking it is just bolted in the front of the seats since they do tumble.Just fold and tumble the seats and you'll see.Has anyone removed second row seats in the Promaster City SLT? I have been told it is easy to do, then I found an article on KBB that says it is difficult.![]()
I removed the front passenger seat once. It was very easy, and only took a couple of minutes.I have removed my rear seats, and it is as simple as removing the bolts and lifting them out. It is the front seats I believe are a PITA to remove. 10 minutes...tops.
That's good to hear. I still need to put G-Mat under the front seats, but I thought I read somewhere that, because of the airbags and harnesses...which I see all under there, and thought it did look rather intimidating...I removed the front passenger seat once. It was very easy, and only took a couple of minutes.
How did you make out with rear seat removal ? Planning to do the same..any advice ?That's good to hear. I still need to put G-Mat under the front seats, but I thought I read somewhere that, because of the airbags and harnesses...which I see all under there, and thought it did look rather intimidating...
If you had no problem, then I shall give it a try and see. Thanks!
I have 3 second row seats for 2017 promaster cargo van .will sell. I'm in n.e. tn.Anyone interested in selling second row seats ?
I'm looking for good used for my SLT, Thanks.
I'm in Raleigh, NC.
I took the whole she-bang outta my SLT passenger wagen. Check out https://www.promasterforum.com/threads/mïks-ram-city-rear-mods.78034/ to see the pics. The seats just bolt in along the front floor, the seatbelt mechanism and air bags are separate deals, with the belts and retractors bolted to the wall behind the plastic panels and the airbags mounted on the side of the compartment high on the door backpost. I ain't got the guts worked up to play with those explosive devices yet. I still have the sliding door panels for both sides, if anyone has a use.Has anyone removed second row seats in the Promaster City SLT? I have been told it is easy to do, then I found an article on KBB that says it is difficult.![]()
I have 2nd row seats. I'm in n.e. tn.
How much do y want to sell one second row seats???
