1 - 9 of 9 Posts
I just put 4x Renogy 100W panels on my roof. I used various VanTech components to mount them. I’ll post complete photos when it is all going. I have four 8ga wires from solar panels going into a combiner box on my roof. The 4 wires together have a squarish cross section (see photo). The round gasket in the fitting that will go into the box won’t seal. How do I keep water out?
Most of us use grommets made to seal one wire and would buy 4.
One option is to combine all the wires on the roof and then run a (heavier) wire set inside.
Which is what we did. However, we avoided those clumsy-looking combining connectors. Instead, we cut the various wires to their required lengths, stripped, soldered and taped.
I went for those clumsy
MC4 connectors engineered to be waterproof and easily disconnected. I also used solar cable pass-through boxes that worked really slick. I felt the DIY cost difference was minimal, especially when it involved the potential for roof leaks.
[ame]https://www.amazon.ca/POWER-GPCEP-Cable-Entry-Plate/dp/B0136USGHY/ref=sr_1_sc_1?ie=UTF8&qid=1519661016&sr=8-1-spell&keywords=gopower+wire[/ame]
I made four smallish holes for my panel wires and used grommets and then a dollop of RV roof sealant atop each. Also hid the holes under the panels so the wires could never be exposed to the sun. I know what damage UV does over time.
Discussion Starter #8
Thank you everyone. Dicor is what I expected to hear.
I used the MC4 combiners to connect 2 sets of 2 panels which gave me 4 wires. I'm connecting everything in parallel and I want to be able to add more panels if I ever need them. I also want as few holes in the roof as possible so I'm using the rooftop combiner box. As I'm married to the combiner box for various reasons, I will use Dicor. My todo list for today already included buying it so I guess I'll be set. I have to be done by Thursday so I have 2.5 days for wiring, which should be fine.
I will post photos when I have solar electricity.
https://www.amazon.com/uxcell-Water...TF8&qid=1519648162&sr=1-9&keywords=wire+gland
If you are committed to doing what you have started then silicone, or better Dicor, good luck.
https://www.amazon.com/Dicor-Non-Le...rd_wg=Ns36N&psc=1&refRID=JSTKDAW7ZD94KXKN7QMY
Just a heads up to anyone using a waterproof adjustable weathertight wire fitting: you must use a circular wire to get a weathertight fitting (not standard duplex wire). For example, AM solar sells 10/2 round roof wire that has a synthetic filler that results in a round outer sheath. This allows the use of a weathertight fitting to get fully weathertight. RD, I'm sure you know this, I just thought I'd post it for others to see.
1 - 9 of 9 Posts
