I am not completely sure about trying to use this portable setup to charge a wide variety of portable devices.
Most modern portable devices are one of the many varieties of Li technology, and the settings for Li Ion cylindrical vs LiPo vs LiFe vs AGM vs flooded usually don't use the same voltage set points, so this might require entering new settings for each device.
My wife can figure out about anything that she is interested in figuring out, but if I asked her to do that, I would get a dirty look. Honestly, I would also at some point mess up as well.
Thanks for the posts
@HarryN
Much Appreciated !!
Solar Panel Quality ,,, We shall see (I took the gamble)
Like you I’m not worried about the voltage drop on 80V
I used blue tape (my red is @ my cabin) on the positive solar wire “both ends” but I can’t screw it up @ the panel
In Canada I think it is “Code” now (these things change so rapidly) to have a “Combiner Box” to collect the array. These combiner boxes have breakers. Apparently “The Blanket” is out 😁
I thought of the Anderson, but I am also thinking of the charger etc on the bottom of a tool box & a tray or cover on top with the alligator clips & wire. Open the toolbox lid, grab the clips/wires, close the lid once the wires are placed into “slots”. Hope that description makes sense.
I might have some sort of connector on the outside of the toolbox for the solar wires to connect to ,,, maybe pigtails MC4s ,,, Pos with a breaker switch
Fusing the positive alligator clip wire was also a consideration (when I hooked it up to my Rolls I of course alligator clipped the terminal fuse not the Rolls terminal).
I think there is a bit of confusion over what I am building this portable charger for. It is not for “portable devices”. It is to charge FLA, AGM, or Lithium batteries. These batteries I can obtain the correct charge profiles the manufacturers recommend & easily user program the Victron to run those charge profiles. I can also save them to files stored within the Victron with names like; AGM Van, FLA Jeep, Lithium Starship (just kidding my Starship runs on AGMs 😜)
I do not own a modern portable device Blueti, etc.
All good info on the solar panel construction - thanks 👍
