Some know that I've purchased Steve's van with lifepo4 batteries. One of the problems with lithium is they can't be charged in cold weather. Steve mentioned that he would just hook up a space heater when it was parked for a while during cold weather. I live in a condo building with a large parking lot but don't have anyway to hookup a heater to run during the winter with shore, so I'm looking for other ways to address charging in cold weather. He also has heating pads that were hooked up to the inverter with an AC controlled thermostat that would turn on at a set temp. While those are nice, they draw around 18-20amps. I can only bring in 12-14amps on a good day so I'd be at a net loss for the day, plus they would run all evening when I have no solar coming in. I think it would just be easier to come up with an automatic way of disabling the solar panels when it's below freezing.
I've got a 12V thermostat (
). I was talking to someone at work and he suggested using an automotive relay. Most automotive relays are Normally Open, so they would require a current all the time to keep it closed. This would be a drain on the system when most of the time, you'd like to keep it closed. 5Pin SPDT relays ([ame]https://www.delcity.net/images/linedrawings/Relay%20Diagram.pdf[/ame]) with an 87a pin can be wired to to be Normally Closed and would only require current when you'd want to open it when temps near the battery reach freezing temps (lets say 36 degrees). However while the coil won't be energized all the time there would be current going through it for half of the day every day when there is solar. I know that most relays aren't used all the time (horns and high beams aren't used continuously) so my concern would be burning out the relay. There are some that are rated for 40-60amps, but I'm still worried that they could burn out. I know they are cheap so i could keep spares and I've even found a base so I could easily swap them out ([ame]https://www.waytekwire.com/item/75290/Relay-Connector/[/ame]) but I'd hate to see them burn out when they would be needed.
Does anyone have any thoughts on this?
