1 - 5 of 5 Posts
Anybody's pm developed a sound under the dash while turning the wheels. Sounds like something rubber that is rubbing. Almost like liquid being slowly pushed through a hose? Strange happens more on a hot day.
Banned
Mine does this, but only since I modded the bolts/washers holding the steering column to bring the wheel lower into my lap.
I have not done anything like that, but it definitely has to do with the steering, almost like there is rubber boots on the steering shaft that are making noise when turned left and right.
So, I found out what it is related to ,, the telescoping steering, If you extend it all the way out, it will make the noise more, there must be a rubber sleave on it or something
Automotive type silicone paste .Good for window channels , weatherstrip and prolly steering shaft to gasket. Sparingly I might add.
1 - 5 of 5 Posts
