Have seen some good photo posts on battery hookups, but in trying to run some cables came up with few questions:
Our aux battery is on the floor right up against the higher cabin floor behind the drivers seat.
1) in trying to run cables out of the veh battery box under the cabin floor to under the drivers seat - there is form between the cabin floor and the frame - did others cut away this foam or simply allow the floor to press the wires down into the foam (wondering if this might damage the wires). To cut away the foam it looks like the whole rubber floor might have to be removed which does not look easy to do vs the panels. How did others do this ?
2) some of the photos show use of fuses at the veh battery terminals but we intend to use breakers instead (allows easy cutoff and eliminates need to carry around extra fuses). The plastic veh battery case looks like we could fit the breakers on the battery ends and would require glue or screws into the plastic - any ideas on this ? Or we could put the breakers under the drivers seat where we plan on putting a 1500 w inverter (should get good cooling under the seat open ends).
3) someone showed a metal container box they bought for under the seat but can't find that post now. Anyone else have experience as to attaching things under the seat ?
our isolator specs a #6 wire at least 6ft total between veh batt - isolator - we plan to have a 100 a breaker between each batt and the isolator. Then run a #2 ground cable between each batt with a 100a breaker in the middle. We will then have separate #2 cables running from the aux batt to 150a breakers to the inverter which should only be about 12-18 inches long total. Then run #12 wires from aux to DC panel.
