Thanks for the detailed response, just wanted to fact check it before proceeding with the project!!Orton style is simply using a smaller inveter off alternator to create 120V and then act as though that is a shore power to charge you battery bank using standard supplied charger (that you use in your house).
Definitely use a larger cable than supplied free with the cheaper inveters. I used a 4 ft marine grade cable - 8 gauge I believe. Size and distance both matter hugely so check manual and a cable calculator. The terminal need to be a ring style and bolted down. Dont use gator clamps or anything that can shake loose.
The positive cable has a fuse at the battery to protect the wiring - I reused the existing 70 amp one from upfitter connection. Most folks are planning to pull around 40 - 60 Amps off the Promaster alternator and it can comfortably handle that all day long.
Things should get warm not hot. Make sure you have air circulation around the inverter and Bluetti - keep the fan areas open. Feel the cable and connections - if any get hot its a sign of problems.
A 500W inverter may be on small size for Bluetti charging since it pulls close to 450W when running and I always prefer a 20% margin or error. That is why I use a 700W.
