Hi @MT BoilerI just bought my Promaster, 136, 2500, HR. Trying to figure out how to 'arrange' solar panels on the roof.
Definitely adding a Maxxair to the back of the van, centered, I think. I am looking at after market roof racks, I think that would be a lot easier. But, pretty comfortable with Renogy solar panels. I get the 175's I would need at least 2, three would go off the side of the van in a straight line, but provide more power than I would probably need.They are 52.3x26.4. If I go with 100's they are are 41.8 x 20.9 .
With a MaxxAir, Fridge, lights and kitchen, I need 300w on the roof to be close, 400w would be plenty. Trying not to scrimp as this is my first experience and I don't want to run out of juice and prefer to not pull off the vehicle battery unless I am using the 12v for 'emergencies'. Three 175's would be over by about an inch if I lined them up straight across. Four 100's would be the same problem. Not sure how that affects the stealth aspect, but I would like to keep the stealth aspect available if I need to sleep on a public street.
Thoughts on how to arrange to panels? I think putting less holes in the roof by using a rack that clamps to the feet is a good idea but am open to ideas on not only racks but install thoughts.
Andy
Yes I did.We can help out, but have you performed the required intro post 1st?
I am not planning on using a battery bank but a Bluetti 2000w Power Station. Can I plug the battery charger into that??B2B charger
No such thing. Actual output rarely comes close to their rated output. Fixed horizontal panels get an average 25% reduction right off the bat. I have 4x100W and have only seen 300W a few times, such as Arizona at high noon. Here on the PNW coast, I rarely see 200W. Right now, under a winter cloud cover, I'm getting a whopping 15W. Many folks also find themselves wanting more/different batteries a year or two down the road. Max out your available roof space and you will never regret it.... but provide more power than I would probably need.
I use 1515 rail instead of unistrut but otherwise do it the same way - fastened to the cleats.I fit 2 NEWPOWA 200's on my 136, plus a maxxfan and skylight. I mounted them sideways. My philisophy was fit as much up there as I could fit, to set you up for any future add-ons. And I'm glad i did.
You might want to read this thread of @Bromaster5;I am not planning on using a battery bank but a Bluetti 2000w Power Station. Can I plug the battery charger into that??
Another thing to think about before I put the walls on!!
🤔🤔Hi,
One thing to have a look at before you make a final decision is this test of MPG penalty for solar roof racks on a van
Basically the extra aero drag of the panels/rack can cost as much as 2+ MPG, or less thant 0.5 MPG depending on how much solar you mount and how you mount it.
I use a single large (315 watt) panel mounted as far back as possible and as close to the roof as possible with no rack - it just mounts to the roof with four angle brackets. All this to reduce aero drag. This has worked well for us and for the same loads as you have provides plenty of solar for most of the year where we use it.
The number of amp-hrs you get from a given panel setup depends strongly on the season of the year and the part of the country you are in. You can use PVWatts to estimate how many amp-hrs you will get out of a solar array depending on loaction and time of year. This page gives some info on how to use PVWatts to tell you how much solar a given set of panels in a given location at a given time of year will produce for you.
The chart below will give you some idea how much solar varies with where you are and time of year .
It tells you how many amp-hrs you get on an average day for 200 watts of solar on the roof for several locations and time of year. Your loads are about the same as mine, and will probably be roughly 60 amp-hrs a day.
If you have more or less solar, just ratio it up or down - eg if you have 400 watts, double the amp-hrs shown on the chart.
Another thing to consider is that how much solar you need depends a lot on how you use the van. Some people boondock for several days in locations that have no place to plug in and get a lot out of solar. Others drive almost every day and really rarely would get any benefit out of solar because their house battery is charged by the alternator.
you can use uni strut channels, made for electrical installations. they come in 10' lengths. lowes & home depot have them. see the attached file for the roof brackets, there are cheaper versions, but these look very well madeI just bought my Promaster, 136, 2500, HR. Trying to figure out how to 'arrange' solar panels on the roof.
Andy
Do you have pictures of how you mounted 4-400 watt panels. I am struggling just figuring 1000 watts and I will have no fan or ac on the lid.We installed a Orion Stealth Roof Rack and were able to mount 4 of the Renogy 400 watt panels east/west and a MaxAir in the rear. It was a tight fit so the measurements had to be right on. We only have a 1000 watt system with 2 100ah batteries. So far we are very happy with our set up.
you may have replied to the wrong person. no pics. I'm mounting 3 panels on 10' unistrutsDo you have pictures of how you mounted 4-400 watt panels. I am struggling just figuring 1000 watts and I will have no fan or ac on the lid.
