There's 3 12mm holes on each side right about in the center, you can see my center rail bolted to one of them. Problem is, the factory interior panels have to go on first which means I can't get a nut behind there. The front and back I used the existing cargo ring location as they are already threaded.
I need to drop in a rivnit, wellnut or plusnut. I'm having trouble figuring out what size I need that will fit that 12mm hole. i have an Astro rivnut tool but it doesn't go that large.
Any ideas?
Any ideas?
