1 - 10 of 10 Posts
I have tryed to post here before with no luck so I will try one more time. Working on 2016 2500 159" high with 3.6 gas. Got questions on auxiliary battery prep. Also lowering rear ride height.
mubiks, type in the search box ( upper right ) what you need and you will find a wealth of information regarding the two subjects you spoke of! Cheers
You should be able to find anything you want to know by searching the archives.
You can ask as well, once you find out enough to get confused and frustrated. Welcome.
Reactions: johnnybesurfing
Aux battery prep
Need to know where to hook the house battery wire. The house battery will be in racing aluminum case under bunk by driver side rear. I see three tabs with 70 amp fuses on top of battery.
Discussion Starter #7
Does the factory battery prep include an isolator for house battery?
Discussion Starter #8
I Still have not got answer if isolator was included in factory battery prep in 2016 model. Did not find in threads.
I guess no one knows. Do you have the Aux Battery Prep? If so you know more than us if not it may be irrelevant. You do need an battery isolator. I just use an old school solenoid which auto-switches when power is applied from the rear power outlet.
See: https://www.amazon.com/Stinger-SGP38-80-AMP-Battery-Isolator/dp/B001HC6UJ0
There are more expensive solutions but this is proven and they have been use in RVs for 50 years.
1 - 10 of 10 Posts
