1 - 9 of 9 Posts
How do you get the light fixture out of the front overhead console? I tried prying, but it doesn't seem to want to give up easily...don't want to break anything.
It says in the service manual that you use a pry stick while pushing the cover forward.
Also it says disconnect the battery first. The whole thing should drop down.
Insert trim stick at the arrow to the right and it will relieve the spring pressure.
PUSH toward the front. It was pretty easy once I read the directions.
I put in LEDS. Not much brighter, but looks good! If you decide to replace with LEDs, make sure you get CANBUS compatible lights.
When you got the cover off, did you discover what the grille between the lights is for?
Been curious what that grille is about.
I was under the impression that was the mic. for the bluetooth phone. It's just a guess though.
1 - 9 of 9 Posts
