21 - 30 of 30 Posts
2016 136 HT Gasser
+1 to all the above AND gloves, tyvek coveralls, a warm jacket, good footwear, eye protection, hand cleaner, rags/paper towels and a big bright flashlight. Think worse case scenario, i.e., it's getting dark and the rain is turning to sleet. Paranoid? Perhaps. Prepared? More so than not.
2016 136 HT Gasser
Wheel hangar pins? How have I never learned of these before? Brilliant! Thank you, Baxsie.
I bought a set of GoTreads after getting stuck in the mud. I like that you can fold one end down under a tire without having the entire length of a flat traction board sticking up in the air. Because they fold up they won't work as a bridge, but I really don't see any of the cheaper traction boards being used that way with what our vans weigh.
I haven't used them for an extraction yet, but they do work well folded up to use as levelling blocks, and they don't take a lot of space. They fold into 4 sections, so you can get 1, 2, 3, or 4 inches of lift depending on how out of level you are. Made in the USA and a lifetime guarrantee.
The other item I consider a must-have is a headlamp - no more trying to hold a flashlight with one hand or in your mouth when you're trying to work on something!
The tire change wrench that comes with the PM is very weak -- I twisted mine right in half.
I carry a 2 ft breaker bar with a 6 point air wrench socket now.
Checking that the gadget that lowers the spare actually works once in a while is good also.
Great advice Gary; what size socket do the lug bolts take? and is your breaker bar 3/4" drive?
Thanks!
Its a 13/16ths socket.
Its a 6 point socket, so more bearing area on the lug bolts than a 12 point, and its an air wrench socket, so its a little more heavily built.
Its a half inch drive, which seems to be enough, but I suppose a 3/4 inch would have a lot more margin.
My breaker bar is probably 40 years old from Craftsman.
2014 PM3500 159 EXT high roof, 3.6L Gasser
@zwarte, could you please tell me/us a little about your winch setup? How its mounted, what brand etc?
I forsee needing one of those...
Also thise trac grabbers are nice, definiteñy an upgrade to putting a ratchet strap thru the wheel
You can find parts on his post here:
I love the setup but it's too much $$ for me on something that I will rarely used.
Thanks for linking, jut found that thread too. i agree, its spendy... for the US i likely will not need it, but once i venture into mexico and points south, one can't have too many self recovery options.
After reading the thread and going to van compass, i now want everything they have available (except for maybe the hammock mount)
21 - 30 of 30 Posts
