OK, so I know these aren't going to ever be great off-roading vehicles, but I actually think this makes having a recovery kit MORE important rather than less important...
On the most recent trip, I had to park in some gravel and loose dirt on the side of the road due to a lack of available space on the pavement. It looked pretty well consolidated, so I pulled in. When pulling back out, the front tires started to dig in a bit and started to dig a bit of a hole. I was able to pull out of the spot with a little tire spinning, but it highlighted exactly how poorly these heavy vehicles are in these circumstances. I think if I hadn't replaced the stock tires with some Falken AT3W tires, it probably would have gotten stuck. (I would have not spun them in and stopped to lower the tire pressure before that happened, though).
I had figured that I would need to put together a bit of a recovery kit even before this, but it impressed upon me just how susceptible the vans are, and so I figured I should assemble a kit sooner rather than later.
Here's my start at a kit. I'm looking for recommendations of specific products or strategies to assemble one that will be suitable for a person who doesn't intend to be going off-roading, but really doesn't ever want to be stuck in a random dirt or sand patch, and who will be in the desert SW a decent amount and doesn't want to be limited to pavement and only the best improved dirt roads
First, deflate the tires! I think down to 25-30 should be about as low as I can go before there are concerns about losing the seal.. Anyone have a specific pressure recommendations to not lose the seal?
Need some kind of convenient deflator:
ARB505 Deflator with pressure gauge.
Need a pump for when back on the pavement.
Viair 300P RVS or 300P, whichever is cheapest when time to buy.
This has sufficient specs to refill the tires in the van up to a reasonable level, but the use duty is possibly a limit if you are trying to get them all the way to 85psi. Not sure, but for occasional use, I think it will be fine from the reviews I have seen. As far as I can tell, the RVS version has a 5' longer hose. That's the only difference. It shouldn't make a difference on a van, but the extra 5' could be useful to avoid having to reposition the pump a lot.
Need a snatch strap to get a pull from someone else.
ARB 705LB
17,500# strength should be plenty. They do make a heavier one, up to 26,000# IIRC.
I'll need a shackle for the rear hitch:
Curt 45832 2" shackle adapter
Tire puncture repair kit...
ARB 11 Tire Kit
I figure this could be the difference between a fun trip and a real hassle, especially if you are in a place where you can't easily get the spare out because of sand/rocks, etc. I once had a puncture in a Subaru that was in a bad place, and thankfully, the slope was high enough that I could back it down to an open area even though I didn't have the traction in the tire anymore. It might have been a lot more difficult if I were on a flat but rugged stretch of trail or in sand.
I've thought about some recovery boards...
FieryRed Recovery Boards
I doubt these make a lot of sense, but as a tool in a toolbox, these could work well in conjunction with deflating the tires, especially for sandy situations. Because of the weight, I expect that four would be needed at times to help keep the van on top of soft sand. I know some people use carpet (my father did that for years while living in UT)... I figure that maybe I could as well, but in the scheme of things, this seems just as viable and not too expensive.
Lastly, a shovel or similar...
Looking for the Aimes E-Tool. This looks like it more or less.
So, I 'm looking for alternates or additional recommendations for what you feel are components of a good recovery kit.
Thanks,
---Michael
Viair 300P-RVS Portable Tire Compressor Kit For RV Towables - 150 PSI
Fill your towable or small RV tires in only a few minutes. With the portable tire compressor on hand, you can forget about finding the nearest gas station or getting stuck on the side of the road with a flat tire.
www.rvupgradestore.com
ARB 705LB
ARB 11 Tire Kit
Amazon.com : Tri-Fold Entrenching Tool (E-Tool), Genuine Military Issue, with Shovel Cover : Camping Shovels : Sports & Outdoors
www.amazon.com
Thanks,
---Michael
