What are you guys using/doing to protect the solar cables on the roof?
Later this week I'm going to install 3 100W Renogy panels in parallel with these https://www.amazon.com/Signstek-Branch-Solar-Adaptor-Connector/dp/B00FWO6ARG
but I'm confused with how to secure the actual cable to the roof. The panels are most likely going to be mounted using aluminum "L" stock and a rhino rack roof rack.
I'm concerned mostly with UV protection and cable rattle. I'm mounting the panels in the center of the roof and planning on running the cables through the backup camera.
Are you guys using VHB tape directly on the wire? Wire inside PVC pipe with VHB tape? I don't want water to pool up around the cables either. I figure I can mount the 3 to 1's underneath the panels for sun protection but I'm uncertain on how most people are securing them. It seems this is a step while trivial, most people don't document in their builds. Can I gorilla tape the adapter cables to the back side of the panels? What about the rest of the exposed positive and negative cable on the roof (about 5' in my case).
