Check out the Gallery for pictures of my semi-finished installation of a Propex propane heater in my 2017 Promaster 1500, 136 High Top. http://www.promasterforum.com/forum/album.php?albumid=1034
I welded 2 custom brackets that span between the undercarriage cross beams. Two threaded studs are welded into the underside of each bracket. The brackets are bonded to the underside of the floor and cross beams with high strength urothane adhesive as well as screwed into the cross beams.Nice job on the install. How did you choose the HS2000 over the HS2800?
Did you weld the tank to your undercarriage or is it bolted through the floor? Any write up/photos on the tank install? Thanks
