21 - 27 of 27 Posts
This.
Top of the list.
Use copper lines and flare fittings.
NOT compression fittings. Compression is for water and non hazardous only. They vibrate and leak.
Don't listen to anyone that says they used compression fittings "and never had any issues".
If you don't know how to flare or don't have a flaring tool, just buy or rent one, or ask a plumber to run the lines.
A plumber buddy might do it for a few beers.
The Propex I bought came with a compression 90 fitting that screws onto the inlet nipple. I purchased a flared one end thread the other 90 & did not use the Propex supplied compression 90.
Yellow gas tape on the threaded end & no tape on the flare end.
Im not a fan of compression fittings either.
Just keep your "crossunder" line behind Xmembers (road debris) and to be extra safe , cover the line with angle iron or SS angle when / if crossing the longitudinals , incase a jack or hoist pad lifts the van on the line .
And no "ice maker " line . Take time to read the NFPA codes and standards relating to RV's etc .
.022 wall is fine for ice makers , .032 is spec'd for propane . .032 would be better crossing under IMO .
All of my tubing is inside the van. There is one T connection and a connection to the heater/stove/propane box. About 12 feet of tubing total.
Discussion Starter #25
So I'm simplifying the design and moving the propane locker, propex, and cooktop all in the same cabinet so I no longer need to run propane line across the van (The cooktop will go above the refrigerator and the propane locker will go on top of the wheel well).....now enters my next question, has anybody put a propex in the location I've attached below?
I'm also showing the underside of the van, where the two outlet pipes will go. Does anyone feel this is too tight a fit? I made this small stencil based on the Propex schematic GoWesty provides. The outer circle is what they recommend as clearance, the inside circle is the size of the actual hole.
62882
62883
It looks tight, but achievable.
My Propex is a 2800 ”green” & your “blue” looks like a 2000. So there might be some differences.
My Propex came with a 90 with a compression fitting. I did not use this fitting as I used a flare 90 fitting. You should make sure you have enough room to get a flare 90 on for your gas line which I am assuming is inside & not coming from under the van.
My 2800 came with an install template from Propex. My “kit”,also came with tubes to hold on the SS intake & exhaust. These are held into place with “hose clamps”. My space was tight also & I ended up enlarging the air intake side to accomodate my thick floor (3/4” BB Plywood & 1” XPS rigid insulation). The exhaust can get hot, thus the clearance requirements from materials that can burn. The air intake is of course colder than the exhaust & the clearances from “combustibles“ may not matter as much. Best to check with GoWesty
It is important to not shorten these intake or exhaust SS tubes - they are sent the same length to provide “balance” or so I was told.
So if the holes fit your intake & exhaust, you can get your propane copper line hooked up to the back of the unit, & the heater has “serviceability” in your chosen location I would say you are good to go.
Good Luck
Mine too.
I had a past RV with underframe propane tank and plumbing and it took a beating from being outside -- required on the road fixes a couple times.
One of my objectives for this conversion was to get it all inside, and it has worked out fine.
21 - 27 of 27 Posts
