New Project, basic "base" build out for phase 1 of a camper build Build will include:
Wall panels, head liner, fantastic fan, dual batteries, full size rear 3 panel bed with cubbies, vented window, and various outlets for portable fridge and electronics. Future plans are to add Possible Solar as well as other minor interior and exterior modifications as they are needed after using the van for a while and figuring out what is "really" needed. I recommend this for any build as often you don't need all the bells and whistles and it's a snow ball effect in costs as we all know when you start adding things such as heat, sink, stove, shower, nice seating... The theme less is more is the focus and have a nice clean interior for two that can be modified in the future. The focus is also to have the van versatile as both a camper and a hauler, not just a dedicated camper. You don't need to do a lot to have a functional van that is also nice inside and to keep the build at a reasonable cost.
Started out with well equipped Diesel 136" High Roof
Basic Sound Proofing and Insulation -using Raam Matt and heat reflective automotive insulation as well as MLV over the wheel wells. My experience has been this is more than adequate to greatly reduce sound and heat/cool air for most applications. Sure you could get crazy. but there is a loss of return to some point in time and material; especially when you have windows that will bring in/out heat or cold air.
Beginning of sound proofing and insulation
Start of Wall Panel Pre-Fit Process
