We did our first winter excursion in ours, and spent 5 days with ~10 degree lows with a ~0 degree low on the last night. The water pump seems to have taken some cold soak and froze up this morning, but just barely. We still had residual hot water coming out of our Isotherm, but the water pump wouldn't work. You could hear it "try" to work with a click when the switch was pressed. A few hours at ~50 degrees here in Denver, and it started to work again. There was a touch of an icy crunch followd by SUPER cold water out of the tap.
We have a Webasto Airtop 2000ST for the interior and it keeps it super toasty at 70-80 degrees depending on how open our ceiling vents are. The garage, separated by a bulkhead, stays pretty cold though (47 degrees), even when we left the bulkhead open all night. And it's apparently even colder in the water box. Makes sense.
For visual context of what the water box and bulkhead look like: http://instagr.am/p/CXZvv_drgPk/
My last van had these heater pads that I would turn on when the weather was under 32 degrees: https://www.amazon.com/gp/product/B01MUC7XI5/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 I had one stuck on the water pump and a couple wrapped around the short water run from water tank to pump and from pump to faucet. They run at 0.333 Amps each, so 3 of them do 1 amp, and I've got plenty of power to run them 24/7 along with the heater and everything else. 200Ah Lithium, 30Ah DC-DC charger, and 400w solar.
I was planning on doing the same thing this time around as well, but didn't know if there were any better ideas out there? It's not really feasible to route any heat from the Webasto back there, as it's under the couch, on the opposite side of the van, and the routing of the air would be a giant PITA.
Thanks!
Thanks!
