1 - 6 of 6 Posts
Checked all my fluids and changed my oil today. Power steering fluid (Pentosin CHF 11S $23.99 a liter) down to minimum and my diesel looked like a Detroit diesel looked like oil all over the power steering motor, hose and oil pan. I'm packing up for my trip back to Texas other wise I would go to a dealer for a fix ill see if they will top off reservoir.
Try spraying an engine cleaner on everthing and hosing it off, then start up and you should be able to see where it is coming from. Loose fitting, or cracked hose or piping might prevent you from getting there. Good luck.
Discussion Starter · #3 ·
P.S. high pressure line LEAK
It appears to be the high pressure line from the electric pump to the P.S.gear/motor diesel part #68167920AA . The line is #2 in the online diagrams and the leak appears to be at the second flex hose crimp from the banjo. The part lists for $248 so everybody check yours before your warranty is up. I know it can be bought for less and a hydraulic shop repair would be less still. Gassers yours is a different part # but still costly.
Maybe You could, if You are out warranty, ask to FCA if they cover it, at least the part cost, since it seems to be a defective part from the supplier.
Discussion Starter · #5 ·
Dealer filled my PS and coolant up, been driving for 2 days and they are still full (to my witness mark). They used Gulf select PS fluid a commercial product. What I found online says it has a leak sealer. When I get back to TX I'll have my dealer look at it.
2016 3500 ext-ht
Having my power steering pump replaced under warranty @96k miles. Pump is currently back ordered with no ETA.
Grateful I found the OP's thread and checked. I never noticed the leak but the fluid was really low and they said the pump was almost shot.
1 - 6 of 6 Posts
