one window is done.
Strange that Tapatalk on my phone posts under a different account oh well.
It took me some time to come up with a final solution but here is how I framed out my motion window.
I first tried unsuccessfully to create individual corner pieces like MsNomer did but quickly realized that it was going to out match any skill and patience I possess.
The window was not 90° to the wall I was putting up so I taped on a couple temporary boards that would represent my wall panel and worked out the angles and depth difference at the top and bottom of the window. I then just made a box to go around the window the top horizontal piece was 2" deep and cut at 2° and the bottom 2.25" deep and 5° joined it with kreg screws to vertical sides. Cut 4 corner pieces using the template guide from installing the windows a little bit of sanding and you have a frame to go around the window.
Next step was attaching it to the wall panel in the right spot so it will all line up. I put up two extra vertical furring strip to act as supports for the window frame, lined it all up and screwed it in place.
I then cut a very rough opening in my wall panel I think I left about 1" extra all around. Applied Lepage Pl polyurethane glue to the front of the frame and installed my wall panel screws and all as if it were going on for good. I brad nailed the panel in a few spots to the frame then removed the panel and clamped everything up and waited for the glue to dry. Once it was all dry I just routed in the final opening, sand, painted and got it all back in place.
Now on to the slider.
