I've come across another design riddle that I'm seeking community guidance to move forward. Any other minds thinking through this with me would be greatly appreciated!
In my galley cabinet, I'm hoping to put my sink above my Isotherm Cruise 85 refrigerator.
The refrigerator is 24.7" tall. The sink I plan on using is 8" deep (tall: top of countertop to bottom of sink basin). I want a 37" tall countertop. Will this work??
I figure: Refrigerator will really take up 26.5" with frame/support below. Thus, I will have 10.5 inches to fit an 8" deep sink and then plumb it across the top of the fridge until I get past the fridge width and can drop the drain line straight down through the floor into my gray tank. Is 2.5 inches enough to fit a drain assembly and a right angle fitting/pipe assembly? I'm doubtful.
I assume that the drain flowing at more or less a right angle pretty much right away is okay for my flow rate? It will be at a slight downward slope, and from my limited plumbing knowledge this coupled with the 2 inches or so of vertical previous to the semi-horizontal 10" run will likely be fine.
Any comments/critiques? I've attached an image of how I'd hope to design the drain-looks like it would take more than 2.5 inches :/.
I realize this is my third new post in 24 hours in our conversion section-thinking I should start a conversion thread and post my questions there.
