Updates - Wow a lot has happened since I hit the road with an unfinished vehicle. Every week I was working I spent about 6 hours working on the build. Still not a ton got done, but I was living and working out of it until March.
< insert Global Pandemic here >
Drove the van back home to Texas gathering supplies along the way.
Back at home, table saw, circular saw, full set of tools, garage, unlimited electricity (relatively)
Work has progressed much faster. Some of which is finishing things I didn't have time for before I hit the road. Redoing things I thought I didn't like. Upgrading other things I thought could be better.
Here are my current projects
Redoing all the plumbing. I didn't put in shutoffs like I wish I had and ended up with a leaky fitting or two. So I am correcting this, in the process I pulled the tank and lined the plumbing compartment with a shower floor liner and a water escape home around my incoming engine coolant lines, if I have a leak it will run out the bottom of the van onto the ground, or harmlessly puddle on the liner. Status - 90% complete, just need to install showhead when I finish the shower walls.
Installing refrigerator. I used an ice chest for a while, and alternately an ARB 50 qt freezer/fridge or Even smaller dometic freezer/fridge (11qt I think). All of these solutions had wires running here and there, and took up floor space. I have decided that although those were ok, to install a permanently mounted refridgerator (TF 49 which I ordered but hasn't come in yet) Status - 10% (measuring, planning, ordering)
Redoing garage storage - A lot of the stuff I had in the garage was parts and tools to finish. I intend to complete this before going back to work, so I won't need the tool and supply storage. I will just carry basic tools and supplies because I will no longer be building - 100%, finished this afternoon.
Complete shower - I never panelled and sealed the shower, and never really needed it. It should be a simple job and as soon as I can go and buy supplies, I will complete this. I may need it more in the future, as the gym where I work may not re-open with Covid19, or could close at any time. I don't know that easy shower at the gym access will be always available in the future, so I will get this done before I hit the road. Status - planning only, no materials
Change toilet - I had a thetford curve, for a porta can it is nice, large and electric. But it is very large and takes up a lot of room in the shower. It is too large to store anywhere else, and it is heavier than I want to move a lot. I tried standing in the shower with it as if I was going to shower and I didn't like it. So I got a smaller model (piston hand pump rather than electric) and installed it on a slide that comes forward from under the bed. I think this will be more suitable. I avoid using the toilet in the van much anyway and this will work fine and save some room. Status - 100%
Finishing - I need to paint, install flooring, wall coverings and in general make it look finished. Status - 10%
Camera system install - Plan to install a 4 camera system. I have no windows other than one back door window to vent the AC, and the cab windows. It is hard to see in some directions so I will install a camera system with one camera on each side and one in the front and one in the back. I will have two monitors, one on the dash and one by my bed so I can 'see' outside the van while asleep. Otherwise there is zero outside visibility from the bed. Status - have the parts and have the plans laid out. It might be part of my progress tomorrow. I almost started on the side cameras today.
What I learned that I didn't know in the last 8 months, I want as much as possible built in and easily accessible. I don't want to move the toilet to shower, or step over a refrigerator, or have to secure things before I drive off. I also want ice for my whiskey. What does that have to do with anything? The TF49 I ordered has a freezer compartment, whereas the ARB and Dometic chests I had can be great freezers, or refrigerators, there is not real way to make ice and keep stuff refridgerated (but not frozen). This is a part of the reason I chose this fridge, I want to keep my drinks cold, and have a tray or two of ice, and I don't want to run two appliances (most of the time, perhaps I will still use the others as second fridges on long trips, probably have them in the garage if I do)
