21 - 25 of 25 Posts
Discussion Starter #23
CABINET OVER DRIVER'S SIDE SLIDER DOOR
This cabinet posed some more challenges, since it had to float over the door.
65725
Same process. Start with metal frame and look for attachment points.
65726
There are six 1/4" bolts holding this frame to the van. Three are in the overhead ribs. The other three are along the outside. Here, you can see the front-most overhead rib bolt and the space I found for the lower, outside bolt.
65727
Here, you see the support for the middle of the cabinet, floating in the slider door opening.
65728
Here is the rear outside bolt.
65729
With the metal frame built, time to build a wooden face frame, make the doors, and scribe some dividers. Again used European Beech with polyurethane.
65730
Discussion Starter #24
Here is a picture of that front outer bolt and the scribed front wall.
65731
Here, you can see that center support and the unique shape of the divider at that location. You can also see the 4" wall that fills the door opening. Also you can see the vinyl matte black sticker material I used to cover the van metal along there, since there's a lot of holes -- never used it before, but I like this material.
65732
Here, you can see the rear wall of the cabinet and the curvature of the 4" wall that fills the door.
65733
This picture shows the depth of the cabinet and the headroom for my son's seat.
65734
Discussion Starter #25
I used the same vinyl material to cover the outside wall.
65735
Here you can see the two recessed LED lights above the doors. Two doors, so I made two lights. Also, this cabinet weighs 35 lbs.
65736
Last photo: the cabinets match.
65737
THANKS FOR LOOKING
21 - 25 of 25 Posts
