Any idea why the nicer seats (6 way adjustable, lumbar support) are not available with the swivel option?
I have the seats with lumbar adjustment and heated seats and installed the swivelsrus CTA aftermarket swivel. No problems. I chose the swivelsrus swivel because the larger center hole accommodated the heated seat wiring without modification. And based on comments from those with the eurocamper swivel, the swivelsrus adapter had fewer issues with obstructions when swiveling the seat.I'm also interested in the swivel seats for a camper conversion. Any idea why the nicer seats (6 way adjustable, lumbar support) are not available with the swivel option? Or at least it appears that way when I try to option them out? Has anyone added an after market swivel to the 6 way adjustable seats? Thanks.
You will be the first non-production RV builder to get factory swivels. I'm really hoping you get them but unfortunately I'm betting it will not come with factory swivel seats.Supposed to get my van with factory swivel seats the end of this month, we'll see if that comes true. When it does happen I'll post pictures. The manual says the van won't launch unless both seats are facing front.
Can you post a pictures of yours swivel sit in following positions; 45*degree, 90* and about 140* ???I did, no problem with my 6 way. I bought a driver's at http://eurocampers.com they have sportscraft a nice swivel and very strong. It doesn't turn around clockwise and you can't sit in it to swivel. http://www.swivelsrus.com carries CTA I believe, also well reviewed and you can turn it clockwise and sit in it to swivel. A bit more $ but I would get theirs.
I've seen aftermarket seats in the RV conversions like that, but the few pictures I have seen of the OEM swivels do not have the belts built in. There is a picture of each seat next to the option choice on the build your own site. The belt is not attached to the seat in those pictures.I've seen a few pictures of the factory swivel seats, and they appear to have the seat-belts integrated into the seat backs, whereas the non-swivel seats have the seat-belt mounted on the B-post.
If the passenger seat is swiveled so it faces backward, are you still able to drive your van? Are your seat belt shoulder straps built into the seat or the A-pillar? Thanks.I did, no problem with my 6 way. I bought a driver's at http://eurocampers.com they have sportscraft a nice swivel and very strong. It doesn't turn around clockwise and you can't sit in it to swivel. http://www.swivelsrus.com carries CTA I believe, also well reviewed and you can turn it clockwise and sit in it to swivel. A bit more $ but I would get theirs.
