2017 Promaster 3500, 3.6L, Gas, AT, 159WB, HR Class B Motorhome
During winter storage of my class b motorhome (promaster 3500 chassis) I disconnect my starter AGM battery and then reconnect it every couple weeks to drive it. If I leave my battery connected it has dropped from 12.7 to 12.0 in a little over a week so I disconnect it.
I always check the battery voltage before reconnection and it usually is 12.7. After reconnecting the negative cable again, I wait about 10-15 minutes before trying to start it, with all door closed, no lights, etc. Most of the time it will start up but occasionally it won't crank when I turn the key and I may have to try multiple times before it will crank and dash indicators come on. I've even had it to where I can't remove the key after failing to start unless I disconnect the negative battery cable letting it sit awhile and then reconnecting the negative battery cable which then seems to release the key.
Thoughts on what is going on and how to fix it??
