You are right I couldn’t find the exact one I ordered so I frustrated myself and then landed on that one. For iPhone etc it must be WIFI NOT Bluetooth for some reason and so:Thanks RD, could you clarify, the link that you gave to Amazon showed the Scanner below, which is not compatible with Mac, I think!,,,,,,,,,,
This item does not ship to Victoria, Canada. Please check other sellers who may ship internationally.
Ships from and sold by ebuyerdeal.
Support all Android Smartphone,and will not compatible with iPhone IPad or any runing IOS sytem or Mac"
I use an OBD reader connected via built-in wifi to an old ipad mini that I mounted just below the radio. I use an app called Dashcommand to view the data, but I haven't found anything that shows DEF level or Regen status. My mount is a magnet mount with a suction cup. The suction cup wouldn't adhere to the slightly rounded panel above the 3 cup holders so I installed it with screws. I also use the ipad with the Garmin app combined with a Dual GPS receiver. I've included some links below.I am looking for an OBD bluetooth reader that works well with the Promaster Diesel. Do any of them give maintenance status and DEF fluid levels? Needs to work with iPhone. Thanks
On the diesel, you can see miles to oil change on the EVIC under the menu (when the van is in neutral and not moving) - just select "Service".I'm not able to see pending maintenance. That's one of my pet peeves of this vehicle, is the inability to see how many kms are due until your next oil change (or DEF fill).
No never heard of it. What does it do?Does anyone have dealer software for firmware updates and actual module controlling ? Using this type of obd2 on other vehicles is eye opening. Anyone there yet with the ram box called ProMaster?
