I'm assuming it's ABS, 3/32", but I wanted a second opinion
I already have the lowers covered, was planning to cover the uppers and the ceiling with a similar nylon sheeting.
Once I get the patterns cut out I was planning to glue sheets of headliner or carpet. Any idea what glue will be the best and if I need to do any prep to the sheets.
Any thoughts on finishing the edges if I use carpet?
I'm going to use the factory styled push pins to secure the panels.
Sheets of poly fill for the insulation.
Neoprene rubber matting glued to the walls for dampening.
