1 - 11 of 11 Posts
Went to drive tonight and my headlights were out. Made sure light switch was on. I have high beams. Is it odd that both low beams would go out. Then .... with the key OUT of the ignition, I turned the light switch on, and the running lights stayed on. With those on, I turned on the high beams and got a message on my dash, "Follow Me 30s", Then "Follow Me 60s" .... I just turned the lights to the off position and left it at that. HELP. Do I need to call an exorcist ?
Amber Electricity Font Gas Automotive lighting
Discussion Starter · #7 ·
OK. Took care of the follow me issue. Low beams are still out. Fuses are good. Next step? New bulbs? Wouldn't I get an bulb error message if the bulbs went out?
If your bulbs are good, it may be a wiring issue. Our dealer told us this is so common they keep replacement head light assemblies in stock. We've replaced the left, and the right is now showing intermittent issues.
2018 136" HR
Have you check the bulbs yet? I know with my 2018, i don't have headlight fuse but its run by the relay with in the computer. I would check the wiring/socket with a multimeter and make sure they are not melted and check the blubs. Its not hard after you do a few times, 10-15 mins tops and there is plenty of youtube video on it.
Discussion Starter · #11 ·
OK ..... fused were good. It's a bit of a chore to remove the headlight assembly to check the bulb .... and it WAS the bulbs. I was not reliant on that because I never got a dashboard error message for the headlights. Got one recently for the license plate light, but not for headlight. Anyway, glad it was just the bulbs. Thanks Guys.
1 - 11 of 11 Posts
