Nexen tires
853 22
Hello to everyone , just bought 4 Nexen tires 225/75/16 for my 2014 Ram Promaster 1500 , but when I received the tires they don’t say lt anywhere instead it says 16C , I called the vendor and I was told is the same , if anyone has any info about this it will be appropriate, thanks
1 - 20 of 23 Posts
2016 3500 ext-ht
Sounds dodgey to me. Who was the vendor?
Administrator
Discussion Starter · #5 ·
That’s because you probably ordered the European "C" specification rather than the E rated one. If they came from the Amazon Nexen store I wouldn’t be to concerned.
[/URL]
Nexen ROADIAN CT8 HL All-Season Radial Tire - 225/75R16C 121/120R E/10 121R this the description
Administrator
Either one is ok for a Promaster - what’s your question/problem ? Are you afraid they are counterfeit tires? It’s doubtful, but contact Amazon if that’s the case or just return them. There is nothing special about that price anyhow.
2016 136 HT Gasser
2019 118" Silver
My question is if this 225/75R/16C is the same as the LT 225/75R/16
Even if not 'exactly' the same tread (looks the same to me) they are M+S rated and the correct tires for your van. Since you already have them 'in stock' I'd have them mounted and enjoy driving around on them.
MMXVI - L2H2 in Indiana
FYI don't use ply # for load index,
From Nexan
OEM tire 10 ply
Rectangle Font Screenshot Magenta Brand
and another 10 ply with a lower load index, the confusing part is someone posted their new van came with these specs
Font Brand Electric blue Auto part Rectangle
(warning, musing ahead) I read the Euro C tires have higher load index but at a lower speed, I wonder if the 115/112 tires would have a higher load index rating if you lower the speed rating.
Font Electric blue Pattern Brand Art
My 2014 I bought new came with Continental 225 75 16 C that's European standard meets us specs I drove 55,000 miles on them no issues construction use
1 - 20 of 23 Posts
