1 - 9 of 9 Posts
The bolt pattern is the same but the center hub of the wheel needs to be bigger, the bolt holes need to be 2mm bigger and the holes need to have a 60* tapper
I have a milling machine, so I bored the center of the wheel to fit the hub of the PM. Then just drilled out the bolt holes from 14mm to 16mm
Just got finished machining these wheels to fit. They are off of a Audi Q7 19x8.5. Also took out my second leaf spring out to level it out and soften the ride.
This is a great look. Have you had any issues with the modified hub?
1 - 9 of 9 Posts
