Not quite.Thanks, Harry, that’s very sweet. I might just take you up on that. I’m overdue for a visit!
Are pin terminals and ferrules the same? I’ll need it on 8AWG wire.
A ferule is essentially a thin copper tube the length of the exposed / stripped wire. It crimps down onto the wire usually from multiple directions and there is a special crimp tool that I do not own for 8 awg. Usually ferules are used for lighter gauge wire like 14 - 18.
What you could also do for a lighter wire is to crimp on a deutch connector pin.
A pin terminal is sort of like a ring terminal - except instead of a ring sticking out on the end, it is a solid "pin" roughly wire size. The more common terminals are insulated - so there is a nylon insulation that is pre-molded onto the terminal.
The type that I use are a heavy duty / non insulated type that is crimped on - and then heat shrinked for insulation. The largest that I have is for 10 awg. I have seen 6 awg but have not found a good source.
Since you have 8 awg, then my approach to this would be to crimp on an 8 awg, non insulated ring lug and cut off the ring. What is left on the wire end will be essentially a ferule - just quite a bit heavier duty. I have those in stock and the related tool.
I use the panduit pro tools setup and it will never come off.
