Hi, I would like to share with you my shelving unit that I built for my 159" high roof promaster. I built everything in my shop and installed after everything was assembled. The units are build with 3/4" MDO plywood and I put 3/4 x 7/8 poplar to cover the plywood edge. The doors are built with 3/4"sapele mahogany and cover the edge with a 1/4 thick x 3/4 solid mahogany, I'm not a big fan of edge banding, I also installed door bumpers so I can put plywood or sheetrock against the doors and take them to the job site. The units have adjustable shelves and are attached to the ribs of the van with 4 (each unit) 5" L brackets as you will see in the pictures. The brackets were screwed to the van with metal screws and attached to the units with 5/16" x 2" long bolts and nuts. The doors have a couple of coats of water base poly. Hope you like it!!! Thanks for taking the time to look!!
Gaston.
Gaston.
