As most of you know, I am in the market for the ProMaster full sized bad boy. Of course, I will purchase one when the redesign comes in. So in the meantime, I picked up the first PMC at my dealer as we were doing an extensive lighting retrofit for them and wanted to throw them some business back.
They can't keep these vans on the lot for long and each time I go back to check on my guys, I notice a different set of them parked out front.
So I bought a very nicely equipped base model as it met my needs. It has the Uconnect radio, tow group, partition (I really wanted that for the summer AZ a/c up front and sound deadening) and some other preferred group packages.
I ordered the roof rack via an eBay seller from the UK along with running boards which I haven't received yet. The rack is super sturdy to hold my 12' ladder when needed.
I have had the bumpers painted with a slight twist on front end styling whereas the white paint is continued under the headlight rather than the silver which goes across the entire band of the grille.
I installed a rearview safety systems camera which is on full time when I drive and turns itself off with the ignition. It is hardwired in. The camera is installed in the stock location on the back door although a little larger than the factory camera.
I installed a Ram mount for my iPhone to hold it securely while I drive.
Things on order are slush mats and splash guards. I will also install the factory driving lights to fill the voids in the front bumper. I hate voids and blanks!
Pardon the construction going on around my property. It is a mess! We are adding on an 1100 square foot garage and soon enough some concrete to park on. All 5k sq feet of it. Concrete is **** pricey around here!!!
