As it stands now I have to drill a hole in the tank and fill it to see if it will flatten out with the weight, if it does not Recpro said to contact them and we would go from there but they usually flatten down.wow, that stinks. I'm looking for a similar style tank (not as large) and was looking at recpro. I may go elsewhere.
I plan to place the fill port on the drivers side toward the top rear, I can only hope the sloshing is not too bad, it is the price I will have to pay to carry so much water.I got a 21 gallon tank from recpro and it seems pretty perfect but it’s taller than wide, so bellowing a little at the sides would go unnoticed. I wonder if those dimensions will ever be a perfect rank, being so long and short. where are the inlets? Water will slosh around in it a lot.
I have really bad sloshing because my driveway is on a hill. It's not been a problem for the fill inlet for me because I just don't fill the tank all the way. But for the vent, It's been suggested by some of the brilliance here that instead of using gravity to keep the sloshing from letting water escape, that I tee it to the pipe that drains the tank and vents the hot water tank. Ask some people here, but maybe a ball valve on your inlet, since there could be near constant water pressure on it?I plan to place the fill port on the drivers side toward the top rear, I can only hope the sloshing is not too bad, it is the price I will have to pay to carry so much water.
Not sure what your installation looks like, but it sounds like what you need is a vent “tube” that goes a bit higher. My tanks are near the rear of the van & my vent tubes extend up the inside of the rear pillars several feet above the top of the tanks. So far any sloshing has not resulted in water traveling up the vent tube and out the top. If that does happen, I will either extend the tube or install 180 degree turn & have it exit under the chassis.I have really bad sloshing because my driveway is on a hill. It's not been a problem for the fill inlet for me because I just don't fill the tank all the way. But for the vent, It's been suggested by some of the brilliance here that instead of using gravity to keep the sloshing from letting water escape, that I tee it to the pipe that drains the tank and vents the hot water tank. Ask some people here, but maybe a ball valve on your inlet, since there could be near constant water pressure on it?
That's what I have now.Not sure what your installation looks like, but it sounds like what you need is a vent “tube” that goes a bit higher. My tanks are near the rear of the van & my vent tubes extend up the inside of the rear pillars several feet above the top of the tanks. So far any sloshing has not resulted in water traveling up the vent tube and out the top. If that does happen, I will either extend the tube or install 180 degree turn & have it exit under the chassis.
Green is the vent tube open @ top / black is the rear pillar;
RV8Rs New Build - TETRIS
I decided to run a 120v 3 wire from behind the drivers seat to the hot water tank location; I may never use this wire & so it might be a waste of $20 of wire & my time. Here is the deal; If I ever get an inverter, I would probably connect it to the starter battery with the idea I would be...www.promasterforum.com
How high above the tank? How many feet?That's what I have now.
Hopefully it will flatten out once you get some water/weight in it. Sounds like Recpro is not going to leave you dissatisfied 👍.I finally received my recpro water tank today after a 3 month wait, I planned my build around this 54 gallon tank as it is low and just fits between the wheel wells with enough room to spare for 1/2" plywood on both sides. View attachment 82439 unfortunately it is terribly distorted and will not sit flush on the floor. View attachment 82440 View attachment 82441 Not the quality that I expected! At this point my options are to live with it or try and get recpro to produce a replacement and hope that the second tank will be better...and wait 3 to 5 months for it to show up.
