This is not something I can answer without some research, but purely from memory
I am not sure if you can trigger on 500W of AC output, but you can setup the inverter to trigger a relay if overloaded. This is typically used to start a generator, but nothing says you cannot use it to turn off a relay that would shut off the water heater.
I am pretty sure you can trigger off inverter output with a GX series device, but I don't see one in your diagram. I think setting up a generator start assistant if the inverter is overloaded will work fine, the inverter can decide when it is overloaded rather than setting a fixed 500W.
I might switch the water heater element to a 1500W anyway as it won't make much difference in usability but can save some stress on your system
