161 - 167 of 167 Posts
Trouble with my Webasto. She's throwing fault code #3 which is an electrical issue -- too low or too high voltage. I've changed nothing in the van and all other systems work fine. Monitoring my Victron I see that upon startup the Webasto draws between 6 and 10 amps and watch my five D31A Yellowtop OPTIMA batteries providing 375 amp-hours start dropping from infinite time remaining to one day in about two minutes. I run this test with no other draw on the fully charged system besides some led indicator lights on rocker switches.
The books says: F 03 Undervoltage or overvoltage 84 The voltage was less than 10.5 V or 21 V for longer than 20 seconds 04 The voltage was more than 16 V or 32 V for longer than 6 seconds. My voltage never leaves the 12's
Maybe for fun try putting a charger on the batteries to bring them into the 13s range and see if that fixes it.
What Harry said !!
I just installed and tested a diesel “barking” heater in my cabin. It uses a bitOpower with heating up the glow plugs. I did not have gauges installed, but my solar charged battery starting the heater it took several minutes for the glow plug to be shut off.
I also tested it with the charger hooked up to the battery, 14volts & the unit fired up and the glow plug was off seemingly under 1 minute.
If you can eliminate the battery bank as an issue, you might find out it is your battery bank, not your heater.
What Harry said !!
This is actually the original reason that I switched to using 24 and 48 volt battery packs and a DC- DC converter for the "12 ish" volt loads.
When it is cold enough outside for the heater to be needed, just a few slightly imperfect things can happen and the voltge in a 12 volt battery pack can be just short of enough to run the heater correctly.
The 10.8 volt Li setup in the goal zeros constantly have this problem.
9 out of 10 people still don't think that this is a good enough reason to use 24 volt battery packs but I keep trying.
Odd but my 216 A-H of FLA have never failed to start my Espar diesel furnace w/o being 24 volts, no B to B charger, no Battery Doctor, no LI, no nothing but two $87 golf cart batteries. KISS
Try a little bit more exciting conditions.
  • sub zero weather
  • batteries at 50% SOC
  • Van soaked at that temp for 24 hrs.
  • Midnight
Lots of things work when the conditions aren't very challenging.
I will admit that my first experience with this problem was a customer with full river agm batteries. Those things are really useless.
I hear you. The 50% SOC would be enough to get me to start the van and drive a half hour and back to a fuel stop or take out. Nothing like fried chicken at midnight, or ice cream in the summer. I haven’t tried it but the problem would be hitting the low voltage cut off on the Espar (if it has one)
