I guess I've officially started this build.
I've started the sound and insulation, using multilayers of materials using aluminum tape, spray adhesive and 1" double sided mounting tape (used over 200 ft just on the roof alone)
1" foam
3/16" closed cell foam to sandwich the mass loaded vinyl
Propex or EZcool
sound mat
Foam duct insulation
Thinsulate 1/2" (will be applying this in multilayers after the wiring is completed)
I will spray foam all the voids prior to paneling.
I've ordered a Onan 2800 generator and decided to install a portable two hose
ac instead of a roof air to keep it stealth.
1" foam
Propex or EZcool
sound mat
