I have purchased a van with the goal of converting it to a safe place, allowing me to travel around to good places.
Condensation is, of course, a huge issue. Because I will be sleeping there and in various climates, I need to insulate it. What I am not clear on is whether I must have a moisture barrier.
It seems to me that it would be impossible to have a totally sealed moisture barrier, especially in a structure that regularly has torque applied to it. This means there will be some condensation between the barrier and the metal side of the van. Also, dust can get in.
It I put holes in the wall / floor as "weep holes", then that allows even more mold food to come in, as well as whatever moisture is in the outside air.
It seems like what I should aim for is insulation I can remove and wash off, wash off the walls of the van, let dry, and then put the insulation back. That, of course, is a tremendous amount of work given that I'll have stuff inside the van.
I'll have one or more small electric dehumidifiers and probably desiccant-type ones, too. But they can fail.
I've searched so much online and nobody seems to think about moisture-barrier failure in a van.
I'm looking for advice!
Thanks.
Thanks.
