1 - 14 of 14 Posts
hey guys, anybody lowered the rear height of the van! I do not like the looks of the rear jacked up? Want it level! How? Thanks for any feed back! tommy
A few have modified the leaf springs so they attach under the axle instead of on top. That's about a 4-inch drop if I recall correctly.
That may be too much of a drop for many. It also has to be done with care to ensure safety.
You should be able to do a search on this lowering topic.
What Chance said... Plus I think most that have moved the axle have also added airbags to bring it back up to level.
I want to re-arch my springs..
But there is only 1 place here in St Louis that'll do it, for 350$.
And they wont do any work on the vehicle. And i have found just 1 shop that will R/R the springs for me at 400$ labor. Dammmnn. 4 days of down time..dammmn
Sounds a bit excessive (cost wise) to me!
Discussion Starter #11
RE Arching Springs? Help!
Ok Guys, seeing several different suggestions as how to lower the rear of my 118 inch 1500, first, do not want to " flip" Axel, don't need air bags, the only thing that's needed in my case, is a 1.5 inch drop in the height to level the van! I'm not concerned with losing weight capacity! I just need to know if anyone has has had the springs " RE Arched"? If so please give me any feed back? I can remove the springs in less than an hour, take them to whoever performs this, then re install! Appreciate any help? Thank you, Tommy
Yes, I had mine re-arched (to lower the rear ride height about 60mm). But in my case, the local truck spring shop did the whole job start to finish including re/re for a couple hundred in cash and a couple hours. If you have air tools and a torque wrench and suitable jacks and stands, I don't see why you couldn't remove/reinstall the springs yourself.
You may wish to consider cutting one convolution off the bump stops - this is easy; they can be pried out of the pockets that they sit in pretty easily and pushed back in afterwards. Easier to do this before you have the springs lowered ...
I wouldn't do this if you are going to be pushing the limits of load capacity. Mine won't see more than about half rated capacity, so it's a non-issue.
Ride quality is close enough to no difference that I can tell.
If you don't trim back the bump stops, you'll hit them more frequently.
1 - 14 of 14 Posts
